How to Automatically Delete Reddit Posts and Comments
If you’ve ever posted on Reddit and later wished you could easily clean up your history, you’re not alone. Now, with Redact.dev’s Disappearing Mode for Reddit, you can automatically delete posts, comments, and upvotes after a certain period of time, without having to manually dig through your account.
While apps like Signal, Telegram, and Snapchat made disappearing messages popular, Redact brings that same convenience to Reddit, helping you maintain a cleaner, more private online presence.
If you’re looking for a simple way to auto-delete Reddit posts, comments. Disappearing Mode makes it easy.
What is Disappearing Mode?
What is Disappearing Mode for Reddit?
Disappearing Mode is a powerful automatic deletion feature that lets you decide how long your Reddit activity stays online before being permanently removed. You can fully control which types of content get deleted, how long you want to keep them, and when they vanish.
With Disappearing Mode on Reddit, you can:
  • Auto-delete posts you’ve made in any subreddit
  • Remove your comments across all threads
  • Maintain a private and up-to-date Reddit profile without constant manual cleanup
How to Set Up Disappearing Mode
Start by downloading and logging into Redact.dev. Once you’re in, open the Disappearing Mode section from the left-hand menu.
Disappearing mode.
Choose Reddit as the platform you want to configure for auto-deletion.
Redact Disappearing Mode Services (April 2025) - Bluesky, Discord, Facebook, Reddit, Twitter.
Select the types of Reddit content you want to delete automatically. Redact gives you the choice to target:
  • Posts
  • Comments
  • Upvotes
Content types for auto-deletion.
Once you’ve chosen what you want to delete, set your preservation window. This controls how long your Reddit content remains visible before it is automatically erased. You can choose any time frame measured in weeks, days, or hours (with a minimum limit of 24 hours).
Preservation window for self-destructing content.
You can also customize additional options:
  • Preserve all current Reddit content and only auto-delete new posts and comments moving forward
Option to only delete new Reddit posts
  • Enable hourly checks for faster and more frequent deletion
Once your rules are saved, Redact will silently monitor your Reddit activity and auto-delete content according to your preferences.
Why You Should Auto-Delete Old Reddit Activity
Setting up auto-deletion for Reddit comes with major advantages:
  • Enhanced Privacy: Old posts and comments that no longer reflect your views won’t be left behind for others to find.
  • Reduced Risk: Decrease the chance of posts being resurfaced out of context or causing problems in the future.
  • Cleaner Profile: Keep your Reddit presence minimal, fresh, and focused on what you care about now.
  • Better Digital Hygiene: Avoid hoarding thousands of old comments or abandoned discussions.
Deleting posts and comments isn’t about hiding. It’s about keeping your digital footprint under your control.
Disappearing Mode handles what you post from here on. To delete the years of posts and comments already on your profile, including comments older than Reddit lists, start with our guide to deleting all your Reddit posts and comments at once.
Ready to start?
Download Redact at redact.dev and set up auto-deletion for Reddit today and if you want to auto-delete posts from other social medias like Twitter, Facebook, Bluesky, and Discord; then check out this tutorial.
Automatically Delete Reddit Posts and Comments FAQ
Can I auto delete my Reddit posts and comments inside the Reddit app?
No. Reddit only deletes posts and comments one at a time, and it has no setting to remove them after a set time. Disappearing Mode in Redact does that for you once you've set it up.
How is Disappearing Mode different from deleting everything at once?
Disappearing Mode keeps working in the background, deleting each post or comment once it's older than the window you set. A one-time run deals with the history already on your profile. Most people do the one-time run first, following our guide to deleting all your Reddit posts and comments, then turn on Disappearing Mode.
Can I keep what's already on my profile and only auto delete new posts?
Yes. Turn on the option to only delete new content when you set up Disappearing Mode. Everything posted before that stays, and only posts and comments made afterwards are deleted once they pass your window.
Should I export my Reddit data before I turn on automatic deletion?
Yes, if there's anything you want to keep. Request your data from Reddit's data request page first, since deleted posts and comments can't be brought back.
Redact for Reddit
