How to Mass Delete MyAnimeList Posts, Reviews, and Lists
Mass Delete MyAnimeList Content
If you’re retiring an old taste, hiding cringe-era reviews, or curating a cleaner public profile, Redact helps you bulk delete your MyAnimeList content with ease. From anime and manga lists to personal blogs and reviews, you stay in full control of what reflects your fandom.
You can clean up your MAL history with Redact.
Please note: mass deleting your MyAnimeList content using Redact requires a Redact Premium subscription. You can try Redact for free on Twitter/X, Discord, Instagram, Facebook, TikTok and many more platforms!
Why Use Redact for MyAnimeList?
Redact offers fine-tuned control over your MyAnimeList data. Instead of manually deleting entries one by one, you can:
  • Search by keyword, date, or content type
  • Filter precisely to avoid losing posts you want to keep
  • Delete your entire anime and manga history if needed
  • Use Preview Mode to see what will be deleted
  • Run Review & Delete for manual post control
2. Connect Your MyAnimeList Account
In Redact.dev, select MyAnimeList from the list of supported platforms.
3. Choose What to Delete
Redact lets you select specific types of content in your MyAnimeList account:
  • Anime Lists
  • Manga Lists
  • Blog Posts
  • Reviews
You can target one type or remove everything at once, depending on your cleanup needs.
Chose content types you want to delete in your MyAnimeList profile including Anime Lists, Manga Lists, Blogs, and Reviews.
If you want to remove content from a particular time period:
  • Set a Start Date to delete posts after that point
  • Set an End Date to remove older content
  • Use the calendar tool to easily select the month or year
  • Click the Reset button to clear your filters
Perfect for deleting posts tied to specific events or outdated opinions.
Redact's Date Range filter, where the Yesterday, Week, Month, Year and All time shortcuts fill in the start date for a MyAnimeList deletion
5. Delete by Post Title or Body Content
Redact allows you to:
  • Delete content based on keywords in the title
  • Delete content based on words or phrases in the body
To clean out specific topics, names, or old reviews, find and remove them quickly by adding keywords to the input field.
Delete according to the title. Input a word or phrase that Redact will search for in the post title. If you’re looking for a specific word to delete in the title of a post, this is where you place it.
Enter a phrase or group of words that Redact searches for in the body of the post. If you’re looking for a specific word to delete in the body of a comment, this is where you specify it.
6. Choose Your Email Deletion Mode
Redact offers four deletion modes to fit your needs, so you can mass delete your MAL content with as much (or as little) precision as you want.
  • Preview Mode: this lets you see all results based on your filters, before you delete anything.
  • Review & Delete: this lets you preview your MyAnimeList content, and bulk-select as many as you want for permanent deletion.
  • Deletion Mode: instantly erases all MyAnimeList content based on your filters.
  • Schedule Deletion: allows you to automate content deletion based on your filters.
We recommend previewing before running a full deletion to avoid accidental loss.
Clean Up Your MAL Profile
Your MyAnimeList history is part of your digital identity. If you’re cleaning up old reviews, hiding outdated ratings, or rebranding your profile, Redact.dev makes it easy to bulk delete content. Protect your privacy and curate a MAL profile that reflects who you are now.
Download Redact and take back control of your MAL profile. You can try Redact for free on Twitter/X, Discord, Instagram, Facebook, TikTok and many more platforms!
Redact also supports a massive range of major social media and productivity platforms, check them out here.
Mass Delete MyAnimeList Posts, Reviews, and Lists FAQ
Can I delete all my MyAnimeList posts and reviews in one step inside MAL?
MAL does not offer a single remove all button for every post and review. You can remove items one by one or use automation that batches actions with filters you control.
What counts as content on MAL that I might want to clean up?
Forum posts, comments, private messages where supported, profile posts, reviews, recommendations, and list entries with notes, tags, and scores.
How do I connect Redact to MyAnimeList and start a bulk cleanup?
Open Redact and choose MyAnimeList. Sign in, then pick the content type such as Reviews, Forum Posts, or Lists. Redact runs on your device and uses the minimum access needed to execute actions you approve.
Which filters can Redact apply for MAL deletions or edits in bulk?
Filter by date ranges, keywords, forum sections, titles, list status such as Completed or Dropped, scores, and tags. Combine Before, After, Between, or All Time with keyword lists for precision.
What modes does Redact provide for MAL cleanups?
Use Preview to review matches, Deletion to remove matches, Review & Delete to approve items, and Schedule Deletion to run recurring sweeps while you maintain your profile.
Can I hide or privatize my lists instead of deleting entries outright?
You can change visibility settings where available to reduce exposure while keeping data. Use delete when you want the record removed from public view entirely.
Does Redact store my MAL credentials or my content on Redact servers?
No. Redact runs on your device and uses the minimum access required to execute your actions. You can disconnect MyAnimeList from Redact at any time.
Should I export my MyAnimeList data before making big changes?
Yes. Export your lists or save copies of important reviews and posts. Store the archive offline or in encrypted storage in case you need a reference later.
How does Redact handle MAL rate limits or very large histories across forums and lists?
Redact batches actions and spaces requests to respect platform limits. For years of activity, run smaller date slices or schedule several passes for stability and full coverage.
Will deleting reviews or posts remove quotes or reposts outside MAL?
No. Deletions affect MyAnimeList only. Screenshots, mirrors, or scraped pages can remain. Use takedown requests or contact site owners when possible.
Can I target only certain list entries such as scores below a value or specific tags?
Yes. Use score filters, statuses such as On Hold or Dropped, tags, and date ranges. Review matches in Preview, then edit or delete as needed.
Is there a free option in Redact for MAL or do I need Premium to clean all time data?
You can start for free with recent history on supported services. Upgrade to Premium to process all time data and get advanced filters and scheduling.
Can Redact schedule recurring MAL cleanups so new activity does not pile up?
Yes. Save your filters and schedule weekly or monthly runs. This keeps your lists and posts aligned with your privacy goals over time.
Will deleting list entries affect my stats or profile graphs on MAL?
Yes. Removing entries changes totals, averages, and history graphs. If you need the numbers later, keep an export before you clean up.
Is Redact easy to try for MyAnimeList, and how do I sign in securely?
You can download Redact for free and start with recent history. Redact uses passwordless sign in with secure email codes. Upgrade any time for all time cleanups and advanced options.
Delete your anime lists, manga lists, blogs, reviews, and favorites
