How to Bulk Delete Discord Messages in Servers and DMs
On this page
Looking to delete your old Discord messages? Maybe it’s privacy, maybe it’s cleanup, maybe you just want the clutter gone. Redact’s Discord tools handle all of it, letting you delete server messages and direct messages in bulk.
With the free version of Redact, you can remove messages from the last 30 days. For unlimited deletion, including your full Discord history, you’ll need to upgrade to a Premium subscription.
Why Delete Discord Messages?
Discord doesn’t offer a native way to delete all of your messages in bulk. You’d have to manually delete each message, which can be time-consuming and frustrating.
There’s more than one reason to clear out your old messages.
- Improve your digital privacy
- Help avoid old messages resurfacing
- Remove outdated or irrelevant conversations
- Clean up your server history
How to Delete Discord Messages with Redact, Step by Step
Step 1: Download Redact
Go to Redact.dev and download the free desktop app. It’s available for Windows, macOS, and mobile devices.
Step 2: Create Your Free Account
Once downloaded, open the app and set up a free Redact account. This will give you access to the basic tools and features.
Step 3: Connect Your Discord Account
- In the Redact dashboard, click on “Discord.”
- Follow the on-screen instructions to connect your account securely.
Worth knowing. Redact doesn’t store your login credentials or data. Everything runs locally on your device.
Step 4: Choose What Messages to Delete
Once connected, you choose what gets deleted.
- Direct Messages (DMs). Wipe everything you’ve sent to specific users, or everyone.
- Server messages. Delete messages in one channel, or every channel.
- Messages by date range. Delete between, before, or after any date.
- Messages with keywords. Only delete messages containing specific words.
Step 5: Use Filters for More Precision
Use the filters to narrow things down.
- Set a date range (e.g., delete everything from January 2020 to January 2023)
- Target messages containing specific keywords or phrases
- Delete by content type, like images, videos, files, or links
- Select specific servers or channels to clean up
You can also combine filters to mass delete Discord DMs and server messages with even more precision.
Step 6: Preview and Confirm
Redact shows you a preview of which messages will be deleted based on your filters.
Once you’re satisfied, hit Start Deleting to bulk delete every Discord message that matches.
Review & Delete gives you more control, letting you hand-pick specific messages. Or set up Schedule Deletion to clear messages automatically after a customizable time period.
Step 7: Let Redact Do the Work
Keep the app open while it works. It’ll go through your history and delete every message that matches your selected criteria.
Final Thoughts
Discord doesn’t make it easy to clean up your past. Redact does. Delete years of messages or just clean out a specific channel; either way, the job that would take days by hand runs in minutes.
Ready to clean up your Discord history?
Download Redact now and start clearing your Discord history today.
Bulk Delete Discord Messages 2025 FAQ
Can I delete all my Discord messages at once inside Discord?
Discord lets you delete individual messages and clear small batches with moderator tools in servers you manage. There’s no single remove-all switch for every DM and channel at once for regular users.
Does deleting a Discord message remove it for everyone?
Yes. When you delete one of your messages, it disappears for everyone in the chat. Discord has no delete-just-for-me option. Moderators can also remove other members’ messages in servers they manage.
Do deletions also remove attachments, embeds, and stickers I posted?
Deleting a message removes that message and Discord-hosted attachments tied to it in that location. External copies and reuploads elsewhere can remain.
How does Redact help me bulk delete Discord messages fast and safely in 2025?
Open Redact and choose Discord. Connect your account, pick targets like DMs or server channels, set filters for dates, keywords, usernames, and content types, run a Preview, then execute deletion or save a schedule.
Which filters does Redact support so I remove risky messages and keep useful ones?
Filter by location, date range, keywords, usernames, and content types like images, videos, files, embeds, and links. Add keyword preservation for anything you want to protect.
Can Redact limit actions to only my messages in shared servers and DMs?
Yes. Redact only deletes your own messages by default. Server moderators can use the Mod Servers option, with the correct permissions, to remove messages from other members where server policy allows.
How do threads, forum channels, and stage channels affect bulk deletion?
Threads can inherit permissions from parent channels and may have locks. Forum posts and comments are separate objects. Confirm each type in Preview before a large pass.
Does Redact store my Discord credentials or message content on Redact servers?
No. Redact runs on your device and uses the minimum access required to execute your actions. You can disconnect Discord from Redact in Settings at any time.
What is a safe workflow to avoid mistakes when removing years of history?
Export what you need first, run a small Preview, approve a short Review & Delete batch, verify, then expand date ranges. Keep preservation keywords for anything that must stay.
How does Redact handle Discord rate limits or very large message volumes in 2025?
Redact batches actions and spaces requests to respect Discord’s limits. For big archives, run by month or by channel and schedule several passes for stability and complete coverage.
Do deletions change roles, server membership, or notification settings?
No. Removing messages doesn’t touch roles, invites, channels, or notification preferences. Those are managed separately.
Can Redact schedule recurring cleanups so new messages don’t pile up later?
Yes. Turn on Disappearing Mode to enforce rules by age or keywords. Pick daily, weekly, or monthly runs and Redact will apply your saved filters automatically.
Can I delete only messages with links, images, or certain words in DMs?
Yes. Use filters for content type, link presence, keywords, and date ranges. Redact only removes messages you sent, so replies from others stay untouched.
Can Redact help me prepare for a background check or job search by scrubbing Discord?
Yes. Set strict filters for keywords and dates, run Preview, approve Review & Delete batches, and save a schedule so new items are handled going forward.
Is Redact easy to try for Discord, and how do I sign in securely to start?
You can download Redact for free and start with recent history. Redact uses passwordless sign in with secure email codes. You can disconnect at any time and upgrade later for all-time cleanups and schedules.
